Easiest question ever...
jhawker23
Jul 20, 2015
7
Jul 20, 2015
7
I'm sick of tracking down my outboard motor's ignition problem and I'm questioning my sanity. These two measurements read .4Ω and 740Ω respectively, correct? Stator Ohms.jpg
davenn
14,260
14,260
yes your first one is showing a short circuit
the second one I cant read the pic is too small, but guessing what range you are on, yes that 740Ω appears to be correct
jhawker23
Jul 20, 2015
7
Jul 20, 2015
7
That's a short circuit? I'm supposed to be getting a reading in the range of .19 - 1.4 ohm
The second pic is on 20k
davenn
14,260
14,260
for all practical purposes yes it's a short
but for the sake of clarification ... there are resistors available that are less than 1 Ohm
how and where you measured this 0.4 Ohms will determine if it's a short or a low value resistor
jhawker23
Jul 20, 2015
7
Jul 20, 2015
7
It's a stator on a boat outboard engine. It shows that is the acceptable range.
Thanks for your help!!
jhawker23
Jul 20, 2015
7
Jul 20, 2015
7
The reason I ask the question is I couldn't tell if its displaying a decimal point or just signifying the value setting.
