Earthing problem
Discussion in 'Electrical Engineering' started by Blair, Jan 24, 2006.
  1. Blair
    Blair Guest
    I have an underground cable controlling a water pump which supplies my house
    , The cable is armoured. Is it necessary to earth the metal armour
    protection?
    Blair
  2. SQLit
    SQLit Guest
    All of the armoured cable connectors I have seen ground automatically,
    because there is a mechanical connection between the cable, the connector,
    and the service.
    If you mean a separate ground wire, no not needed
  3. Blumpkin
    Blumpkin Guest
    From your news provider I see you are from the UK.
    So, yes it is necessary to comply with regs.
    Blumpkin..
  4. Blair
    Blair Guest
    Thanks to all who replied
    I should have said that I have a metal junction box at present where the
    cable armour
    is earthed but I am proposing to change this to a plastic
    junction box, and there will be no earth available for the armour.
    Can I safely do this?
    Blair
  5. Why not use a locknut for the cable gland that has a terminal for an earth
    or an earthing tab that goes under the gland locknut?
  6. Blair
    Blair Guest
    Thanks. To make sure what you are proposing is this correct
    Wire the earth tab on the cable gland to the earth wire within the 3 core
    cable itself?
    Blair
