OK
here's a list compiled so far
Item ...... Count ....... Description
2732 3 EPROM
7416 3 Hex Inverting Buffers with High Voltage Open-Collector Outputs
7473 6 Dual Master-Slave J-K Flip-Flops with Clear
27128 1 EPROM
(DT)5A143E 4 Digital Transistor Array, Including Resistors
1N4148 4 Diode
1N5224 12 2.8V 0.5W Zener -- code marking 3381
1S03 3 Photo-interrupter Sensor, right angle mount
2SA1008 3 PNP Transistor
2SA1015 8 PNP Transistor
2SA1444 4 PNP Transistor ( On Heatsink )
2SA413 17 PNP Transistor
2SB595 2 PNP Transistor
2SB751 2 PNP Transistor
2SC1959 5 NPN Transistor
2SC3328 10 NPN Transistor
2SC3567 6 NPN Transistor
2SC4742 1 NPN Transistor
2SD1128 1 NPN Transistor ( on Heatsink)
2SD1263 10 NPN Transistor
2SD1276 1 NPN Transistor
2SD1395 1 NPN Transistor
2SD1809 7 NPN Transistor
2SD1838 19 NPN Transistor
2SD560 20 NPN Transistor
2SD633 4 NPN Transistor
2SJ268 12 P-Channel Power MOSFET
6N136 5 High Speed Optocoupler 1Mbit/sec, 2MHz B/W
74ALS00 10 SMD - Quad 2-Input NAND Gate
74HC32 6 Quad 2-Input OR Gate
74HC174 5 Hex D-Type Flip-Flop
74HC244 2 Octal Buffers and Line Drivers, With 3-State Outputs
74HC245 1 High Speed Non-Inverting Octal-Bus Transceivers with 3-State Outputs
74HC273 10 Octal D-type flip-flop with reset; positive-edge trigger
74HC86 2 Quad 2-input Exclusive OR gates with push-pull Outputs (SMD)
74LS04 4 Hex Inverter (SMD)
74LS04 2 Hex Inverter
74LS123 9 Dual Retriggerable Monostable Multivibrators with Clear
74LS156 2 Dual 1 line to 4 line Demultiplexer
74LS221 6 Dual Monostable Multivibrator Schmitt Trigger
74LS244 2 Octal 3-STATE Buffer/Line Driver/Line Receiver
74LS244 8 Octal Buffers and Line Drivers, With 3-State Outputs (SMD)
74LS245 2 Non-Inverting Octal-Bus Transceivers with 3-State Outputs
74LS38 2 Quad 2-input NAND Buffer
93C46CB 5 Serial EEPROM
ADM211EAR 3 Transceiver (SMD)
AN7918 2 Neg 18V Regulator
B81004 15 Schottky Diode, 40V 3A
BA10339 4 Comparator, Quad channel, Open collector and emitter, 36V
BA6266 7 6-channel inverter
BL514 3 Photo-diode ?
CK2605 11 Programmable Logic Device Data I/O
D4713 3 RS232 Driver/Receiver
D71059C 2 Interrupt control unit
D7210C 1 Intelligent Gpib Controller
D78CP14CW 2 8-BIT SINGLE-CHIP MICROCOMPUTER
D82C288-8 4 PROM ( Pre-programmed)
EC-977 1 ?
EC-A325 2 ?
EP-390 5 M-ROM
GP1A01 3 Photo-interrupter Sensor, Vertical mount, sup-ceeded by GP1A50HR
GP1A51HR 2 Photo-interrupter Sensor, right angle mount
GP1S50 7 Photo-interrupter Sensor, Vertical mount
HA16901P 5 Quad voltage comparators
HA17301P 5 Quad Operational Amplifier
HDSP5621 14 Twin 7 segment displays ( LED) Green
HM6116LP-4 1 2048-word x 8-Bit High Speed CMOS Static RAM
KM6264BL-10 3 8K x 8 Bit High Speed CMOS Static RAM
L917 10
LB1268 3 3-Channel High-Current Low-Saturation Driver
LB1650 4 Dual Bidirectional Motor Driver
LM305AP 5 Positive Voltage Regulator
LM393 3 Dual Differential Comparators
LT1081CN 2 Advanced Low Power 5V RS232 Dual Driver/Receiver
M51957 1 Voltage Detecting, System Resetting IC Series
M5230L 3 Variable Output Voltage Regulator (Dual Tracking Type)
M54580P 6 7-Unit 150 mA Source Type Darlington Transistor Array
MB84060 5 14 Bit Binary Counter
MC14001 6 Quad 2 Input NOR Gate
MC14016 2 Quad Analog Switch/Quad Multiplexer
MC1488 6 RS-232 quad line driver
MC3301 2 Quad Single Suppy Op-Amp
MC3486 1 Quad differential line receiver
MC3487 2 Quad Differential Line Transceiver
MTZJ24B 13 Zener Diode
OP11 2 Quad Matched 741-Type Operational Amplifiers
PBL3717 6 Stepper Motor Driver
PS2501 9 6V 50mA phototransistor optically coupled isolator (SMD)
RN1002 1 NPN Transistor (Built-in Bias Resistors)
RN1201 7 NPN Digital Transistor (Built in Bias Resistors)
RN1202 5 NPN Transistor (Built-in Bias Resistors)
RN2002 18 PNP Digital Transistor (Built in Bias Resistors)
RN2201 10 PNP Transistor (Built-in Bias resistors)
RP5C15 2 Real-time Clock
S101DD2 1 Bi-directional Opto Thyristor
S81250AG 4 Transistor ?
SN75114 2 Dual Differential Line Drivers
SN75116 2 Differential Line Transceiver
SN75150 4 Dual Line Driver
SN75160BN 4 8-Channel Bidirectional Transceiver
SN75161BN 4 Octal general-purpose interface bus transceivers
SN75189 10 Quad line receiver
STK6713AMK4 2 unipolar 2-phase stepping motor driver (MOSFET)
STK7563K 3 Voltage Reg Module
T520C 4 Transistor ?
TA75339P 9 Quad Comparator, Open drain-collector, 36V
TC4029 3 Presettable Up-Down Counter
TC4049 10 HEX Buffer Converter - inverting
TC4056 4 LCD Display Driver
TC4069 1 Inverting-Function Buffer Gate
TC40H032 5 Quad 2-Input OR Gate
TC40H245 13 Octal Bidirectional Bus Buffer Noninverted 3-State Outputs.
TC40H273 4 Octal D-Type Flip-Flop
TC40HC373 13 is it the same as a 74HC373 ?
TC4514 7 4-bit latch/4-to16 line decoder
TC4543 3 LCD 7Seg Latch-Decoder-Driver
TC4584 5 Hex schmitt trigger
TC5012 16 Hex Non-inverting 3-State Buffer
TC5066 24 7 x High Voltage Buffer, Non-inverting
TC5092A 1 Analog-to-Digital Converter, 13-Bit
TD62004 4 7CH Darlington Sink Driver
TD62064P 2 4CH High-Current Darlington Sink Driver
TD62781AP 6 8 Channel Current Transistor Array Driver
TD62871 12 8-Ch High Voltage Source Driver
TDA1170 1 Vertical Deflection (TV)
TL7705 6 Supply voltage Supervisor
TP850 8 Photo-interrupter Sensor, Vertical mount
UA741 1 Op-Amp
UDN6118 3 Fluorescent Display Drivers
ULN2803A7 5 High-Voltage, High-Current Darlington Transistor Array
uPC141C 6 Precision Positive Voltage Regulator
uPC271C 5 Precision Voltage Comparators same as uPC/LM311
uPD4712A 5 Quad RS232 Line Driver/Receiver
uPD71059C 2 Interrupt Control Unit
