Hi, (sorry I can't access the Eagle newsgroups).
me too ;-)
I noticed that the output files for the top and bottom include the
pads. Does that mean that the pads will be manufacturered so that it
can be soldered from the top or from the bottom?
the idea is to mfg a board that can be wave soldered from the solder
side and the solder flows to the component side. that's what through
hole plating is for. well, one thing, anyway. you can hand solder a
plated through hole from one side and get this to work, also. hint -
flux helps.
PCB parts are designed to work on multiple layers. you'd have to copy
the part (use different name) and edit it. that should be doable but i'd
just leave things as is.
The reason I ask is that I have a few components that we would like to
solder from the top, rather than the bottom. I don't know how to set
the layers on this to do this.
turning off a layer will do away with anything on that layer. that's not
what you want.
this is general info not specific to Eagle. when you edit the part, look
for options regarding whether edits apply to the current layer only, or
to all layers. set it to edit current layer only. select the layer(s)
you want to remove the pad from and delete it for each layer applicable.
maybe the layer edit option will apply to edits done to the whole
layout, but i wouldn't count on it. i don't know because i don't obsess
about pads like that and therefore have no need to do this.
now that i think about it, placing a single pad on the board and editing
it from one side (or just putting it on one side) should work, but when
you try to select a pad that belongs to a part (footprint) it selects
the whole part, so a part edit would be required unless you just place
pads.
here's something that MIGHT help creating parts:
ftp://ftp.cadsoft.de/pub/userfiles/doc/eagapp3.zip
The through-hole pads are always just
a "green" layer. Are all through-hole pads able to accommodate for
choosing between soldering from the top or the bottom?
if the board has pads on both sides, it's up to you what you solder.
just don't expect a top side solder joint to be connected to a trace
coming off of an unsoldered pad on the bottom unless you have plated
through holes. i guess that's what you'll get since IIRC Eagle supplies
that sofware as a courtesy to PCB customers. maybe i'm thinking of
another free PCB tool. i'm guessing that's what you're planning to do
since you asked if it would be manufactured ...
I just want it like a regular through-hole pad where the pad is on the
top.
picky, picky ;-)
that's NOT regular. solder-side only would be "regular" but only on a
single sided board. leave the poor pad alone. it won't bother anyone
else.
