Eagle Layout
Discussion in 'CAD' started by Ron J, Jan 31, 2006.
  1. Ron J
    Ron J Guest
    Hi!
    I have some components that need to be spaced closely to each other. I
    was wondering how I can re-position the name / value text of these
    components. It seems the name / value of the components are anchored to
    the position of the component.
    Thanks!
  2. Ron,
    First, you will likely get better responses from the Eagle dedicated
    news groups - eagle.support.eng and eagle.userchat.eng which you can
    access directly at news.cadsoft.de.
    Second, if you use the "Smash" command on the componets after you place
    them in a schematic or board, you can then move the name and value texts
    anywhere you want.
  3. JeffM
    JeffM Guest
  4. Ron J
    Ron J Guest
    Thanks, James!
    I tried searching for Eagle in Google Groups, but I guess it doesn't
    have it listed. I'm posting via Google.
  5. JeffM
    JeffM Guest
    You're right. It's not archived there.
    The CadSoft newsgroups are VERY valuable for an EAGLE newbie.
    This is where a real newsreader is handy.
    http://groups.google.com/group/sci....6396d9e9?q=gravity-forte-xnews-40tude-mozilla
    You will need access to Port 119 from yor ISP
    and a NNTP provider that is worth a damn (perhaps your ISP again).
    http://www.google.com/search?q=getting-started+newsgroups+-inurl:microsoft.com
    BTW, EAGLE is an initialism for Easily Applicable Graphical Layout
    Editor
    and properly is all caps.
  6. shwetha
    shwetha Guest
    Hi all,
    I want to build a board with a DSP, a codec and 4 microphones with a
    battery supply. I would like to do the schematic using the EAGLE
    software and this is the first time that I am using EAGLE. I tried do
    some simple schematic as explained in a online tutorial. And I am
    using the BF533 and AD1863 codec. so how do Igo about drawing the
    schematic? I need some guidance regarding the same. I hope to here from
    you all at the earliest.
    Thank you all in advance
    shwetha
