EAGLE CAD board through-hole design issue?
Discussion in 'General Electronics Discussion' started by rigers, Dec 18, 2011.
  1. rigers
    rigers
    Dec 18, 2011
    Hello,
    I'm designing a PCB on EAGLE CAD but there seems to be a problem. I am making a circular PCB and it has a .750 inch hole in the middle. The problem is that EAGLE only allows drill sizes up to 0.516024 inch. Does anybody know a way to get around this?
  2. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    Hi rigers,
    I am not an Eagle CAD user however the think to do is to place a so called "internal cutout" or similar.
    still need to find it in the menu's.
    Olivier
  3. IRETST
    IRETST
    4
    Dec 7, 2011
    If you are generating CNC & Gerber data then simply edit the drill table & header on the CNC to show tool X = to 0.75" -
  4. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    Modifying the production files will certainly work but it's a bad practice.
    The next time the PCB is edited you can forget to apply the trick :(
    Olivier
  5. IRETST
    IRETST
    4
    Dec 7, 2011
    Agreed - but it is a solution that can be used if you are tearing your hair out looking for one!
