Eagle Autoroute Problem
Discussion in 'General Electronics Discussion' started by pilko, Aug 5, 2013.
  1. pilko
    pilko
    26
    10
    Dec 8, 2012
    Hi everyone,
    When I autoroute in Eagle, the traces extend into the center of pads and vias. Copper is therefore filling the drill hole locations making it difficult to position the drill bit to the center of the hole. I have to manually shorten the traces to the perimeters of the pads and vias.
    Can anyone please explain why it does this and what I can do to prevent it?
  2. Rleo6965
    Rleo6965
    585
    9
    Jan 22, 2012
    I have same problem printing pcb file using DesignSpark5 pcb software.
    I solved by adding PDF printer in Windows. Then Print Setup and select added PDF printer.
    Print your pcb file and select Windows in Printer Output Menu. Don't select PDF.
    Hope this help.
    Let me know if it works.
  3. Harald Kapp
    11,513
    2,651
    Try the user language program "drill-aid.ulp".
    More info see here.
  4. pilko
    pilko
    26
    10
    Dec 8, 2012
    Thanks for the responses and info Rleo6965 and Harald.
    I have found that when I print, the problem no longer exists.
