Dynamo Air Hockey Table Need help with main board
Discussion in 'Troubleshooting and Repair' started by roastedrick, Sep 18, 2017.
  1. roastedrick
    roastedrick
    7
    Sep 18, 2017
    I have a dynamo air hockey table from 1987. The score isn't working anymore and the game shuts off after a few minutes playing. I was told I probably need a board. However it's $300. Does anyone know of a person/company that can fix the board? The 2nd question would be does anyone know where I can get the main controller board pcb v7.0 cheaper then $300. I was hoping to keep it under $150. Thanks for any help.
    adam899 likes this.
  2. 73's de Edd
    73's de Edd
    2,920
    1,235
    Aug 21, 2015
  3. adam899
    adam899
    Feb 5, 2019
    Hey roastedrick, are you still seeking for the company which can provide you board. So you muct check out https://airhockeytablereviews.com/ and you get all answers regarding your air hockey table.
  4. 73's de Edd
    73's de Edd
    2,920
    1,235
    Aug 21, 2015
    Sir roastedrick . . . . .
    It looks like Valley and Dynamo are wed and now sleeping in the same bed . . . so look at these supplied links and see if it shows electro / mechanical similarities to your unit . . . .
    My most significant observation is the use of a hefty storage battery to be able to play keep up on current demands.
    You may have lucked out and are only having a power supply failure issue . . . . otherwise . .. they "own you" on a bad main board or any info on it .
    Plus that price is not outrageous, if you had initially paid 5K for a unit .
    Otherwise, if you fould it as a freebie . . . . you are are falling into the category of being a beggar . . . and beggars can't be choosey.
    http://valley-dynamoparts.com/dynamo_schemas.asp
    http://valley-dynamoparts.com/docs/2016BlackHoleHockeyManualFINALREVISION.pdf
    https://www.betsonparts.com/downloads/dl/file/id/49/hockey_wiring_diagram.pdf
    https://www.betsonparts.com/downloads/dl/file/id/47/hockey_logic_version_7.pdf
    https://www.betsonparts.com/downloads/dl/file/id/51/hot_flash_overhead_installation.pdf
    https://www.betsonparts.com/downloads/dl/file/id/52/photon_overhead_installation.pdf
    https://www.betsonparts.com/downloads/dl/file/id/48/hockey_logic_version_6.pdf
    https://www.betsonparts.com/downloads/dl/file/id/46/hockey_display_overhead.pdf
    https://www.betsonparts.com/downloads/dl/file/id/45/display_side_schematic.pdf
    Do any of these relate to your unit . . . . . , since you didn't further identify its specific model ?
    73's de Edd . . . . .
    If a stealth bomber crashes in a forest, will it make a sound ?
  5. KashootMe
    KashootMe
    May 15, 2020
    I have a similar question. I’ve got a shuffle board that has a scoreboard that no longer seems to be working. It appears that the scoreboard is from a Dynamo air hockey table. The main control board is what I am looking to replace. It is from 1989 and says “air hockey v3” If anyone can help me figure out where to find one(I can’t find any anywhere) I would be very great full
