DVR
Discussion in 'Security Alarms' started by [email protected], Jul 6, 2006.
  1. Guest
    Anyone have any recommendations on DVR technology? I have a 4 channel
    DVR but it doesn't cut it. First generation DVR technology and very
    grainy at night.
  2. Doug L
    Doug L Guest
    The poor performance at night is probably due to the cameras and or lighting
    conditions, not the DVR.
    What cameras and DVR do you have and what are you hoping to achieve
    Doug
  3. bart
    bart Guest
    As Doug mentioned grainy images are probably due to cameras. If you are
    using night vision, you can get IR illuminators to light up the place
    at night.
    I have been using Nuvico for DVR - and they work great. It is not
    converted from a PC, and it's a standalone machine, you can add a
    harddrive to increase capacity, take backups to USB and CD. The rest of
    the specs are the same as other DVRs.
    Baris
  4. Guest
    I am using Smarthome's most expensive color camera with more IR
    illuminators than you can shake a stick at. I am wondering if this it
    is just not a good camera.
    Here is the URL: http://www.smarthome.com/7546b.html
  5. Guest
    What night vision camera would you recommend?
  6. DA
    DA Guest
    Most DVRs have picture quality control that lets you choose between
    quality and storage. Better pictures = shorter archive. If you had yours
    setup for most storage, you'll really sacrifice quality. Additionally,
    pictures on DVRs are usually grainier than your analog monitor viewing
    because you don't have the CRT pixel smearing that smoothes out any sharp
    edges. On top of that, you always have some quality loss due to
    compression, even at high quality setting and also, especially on those PC
    converts, you are watching the picture on a monitor that has resolution
    much higher than your camera and all the pixels look blown up.
    The camera that you got from Smarthome looks quite OK as far as its spec.
    It's actually better then just OK, it looks great. Make sure you have all
    the DIP switches (if any) in correct positions for AGC and backlight
    compensation (depending on the actual lighting condition at the site). You
    also want to make sure the camera is not looking directly at some light
    source that you might have missed when installing camera during a day.
    Good luck!
    D~
    Delivered via http://www.secure-gear.co
    The Internet Knowledge Base for the security industr
    no-spam access to your favorite newsgroup -
    alt.security.alarms - 19016 messages and counting
  7. Bob La Londe
    Bob La Londe Guest
    I've got a couple of these on the shelf and they seem to do pretty good at
    night.
    http://www.scdlink.com/shop/shopexd.asp?id=1189
    Haven't had any in service long enough to tell you about their durability.
    Just played with them to see how well they light things up.
  8. Jim
    Jim Guest
    Bob, is it using a board camera?
    How's the resolution at night?
    How much did it cost?
    Are the connections weather protected?
    Were you able to tell who the manufacturer is?
    Do you know if they come with other lenses?
    What are the actual dimensions?
    Thanks.
  9. Bob La Londe
    Bob La Londe Guest
    Sorta, but all cameras are board cameras. LOL. Has a bigger lens than most
    though.
    Decent out to about 30 or 40 feet.
    I won't give delaer prices on the group. If yer a dealer call SCD and ask
    them.
    No, but I can modify that easy enough.
    Does not.
    About the same as a regular outdoor housing.
    Yer welcome
