DVR 620 Ejects tape and powers off
Discussion in 'General Electronics Discussion' started by Pistol803, Feb 21, 2018.
  1. Pistol803
    Pistol803
    Feb 21, 2018
    This is a Toshiba DVR 620. Emmediately after putting in VHS tape it powers off and ejects the tape. How can I stop this from happening?
  2. kellys_eye
    kellys_eye
    4,275
    1,146
    Jun 25, 2010
    Repair it.
  3. Tha fios agaibh
    Tha fios agaibh
    2,128
    720
    Aug 11, 2014
    Or, don't put a tape in it.
  4. Tha fios agaibh
    Tha fios agaibh
    2,128
    720
    Aug 11, 2014
    I will say that some will fault if the mechanism is overloaded (binding) or if a belt is slipping. It's very likely your belts are worn out due to age.
    Cirkit likes this.
  5. CTP4500
    CTP4500
    21
    Mar 3, 2018
    The laser is reading a damaged tape. Clean it with an air blower. Then try it again. ok not. It shuts off because the circuits cannot read the tape. Constant power is not used. Timer to this device. lever is broken. a lock is loose, cannot lock. Check the power supply.
