DVD spindle motor replacements.
Discussion in 'Electronic Repair' started by David Farber, Jan 21, 2004.
  1. David Farber
    David Farber Guest
    I have two DVD players in my shop. One is a Mitsubishi DD-6000, the other is a
    Toshiba SD-1300A. They both have bad spindle motors caused by flimsy brushes.
    One of the motors has a direct short across the dc input, the other one had
    very low torque. Both manufacturers make you buy the entire assembly, laser,
    etc., in order to get a new spindle motor. This assembly is over $110. As you
    can see by the photo of these motors:
    http://www.pbase.com/image/25340423/ they seem very similar. I tried removing
    the motor casing to repair it but it is nearly impossible to do so without
    deforming the metal enclosure. Does anyone know of a generic type replacement
    for this type of motor. It doesn't seem much more complicated than a regular cd
    spindle motor except that there is an extra optical sensing device to regulate
    speed.
    Thanks for your reply.
    David Farber
    David Farber's Service Center
    L.A., CA
  2. Many small motors like this have small slits at the bottom. You can spray
    cleaner/lubricant into the slits, aimed at the brushes, while turning the
    motor. Use compressed air to blow out debris and excess lubricant. Repeat
    til short cleared. Very effective, fixed lots of cd motors this way over the
    years, only ever had 1 re-do.
    You can even connect a variable dc supply to the motor, run it at a given
    speed, spray the cleaner at the brushes and really notice the motor "taking
    off" when the short clears.
    The brushes pick up carbon from sparking, which shorts out eventually. I
    _think_ a silicon based lubricant will prevent future carbonization.
    Mark Z.
  3. David Farber
    David Farber Guest
  4. Read the review - sounds like even worse junk than I'm used to.
    mz
  5. Whome
    Whome Guest
    I can supply you wit your hard to find numbers. I salvage those CD
    roms that are not sold or display models. Motors are like new.
    I sell single item at reasonable costs.
    therepairman at optonline.net
  6. David Farber
    David Farber Guest
    Hi there,
    I don't think I need those motors any more as I posted that message more
    than nine years ago. (-:
  7. Jeroni Paul
    Jeroni Paul Guest
    I have successfully removed the casing and reassembled motors like the one in the photo successfully. It requires patience. You may try Mark D. Zacharias procedure first, sounds good.
  8. John-Del
    John-Del Guest
    LOL! In an age of $70 blue ray players, I was wondering who was repairing any DVDs anymore!
  9. I found a blu-ray player on the sidewalk three weeks ago, when everyone
    was moving. The front panel of the drawer was missing, as if a disc had
    gotten stuck and they'd tried to pry open the drawer. I plug it in, the
    display says "power on" and then it seems to turn off. But hooking it up,
    it plays a DVD fine, there's a feature to turn off the display. I have to
    get a blu-ray movie to try that, but it seems fine.
    No remote, which perhaps is the issue. A lot of these things need the
    original remote to do much. And this one is relatively fancy, has an
    ethernet port so it can do internet things. Apparently one can hook up a
    USB keyboard, I hope but doubt that that would mean I can control it from
    the keyboard.
    And like my tv set, and like my TomTom One $10 garage sale GPS, this too
    uses LInux.
    Michael
  10. Jeroni Paul
    Jeroni Paul Guest
    An economical way I have found to use things like these when the original remote is missing is to buy two universal remotes at least one with learningcapability. They are cheap. It is very likely there are some codes in the universal remote that will work most functions but with keys incorrectly mapped to buttons. It is unlikely you will find a working code with keys correctly mapped, at least with todays cheap no name brand devices where all ofthem seem to share a manufacturer but have different remote key codes.
    To search for a code keep the device turned on while using the remote search funcion, as soon as you see any response, stop and try all buttons, surely many of them will trigger different responses.
    At this point use the learning remote to map them to the correct key according to the observed response. After a while you end with a fully functionalremote for that device.
