Dual Monitor using VGA Splitter
Discussion in 'Electronics Homework Help' started by krishna_gopal_2, May 20, 2013.
  1. krishna_gopal_2
    krishna_gopal_2
    4
    May 12, 2013
    Can I extend my monitor display to another monitor using an VGA Splitter?
  2. (*steve*)
    25,497
    2,838
    No...
  3. (*steve*)
    25,497
    2,838
    Let's expand on that. I assume you mean a VGA splitter which takes one VGA output and displays the same image on two or more monitors.
    Extending the display of a computer to a second monitor requires that both displays show different things.
    This fundamental difference is why I gave the simple answer above.
  4. krishna_gopal_2
    krishna_gopal_2
    4
    May 12, 2013
    Then, what should I do to EXTEND the display. I am a share broker. So no gaming purpose. Just for using charts.
  5. (*steve*)
    25,497
    2,838
    The easiest approach (especially if you're running Windows 7) is to change your display card to one that has dual monitor outputs.
    You may also be able to simply add another display card to your computer, but if you're using the display hardware on the motherboard you may have to disable it before the computer will look at the new card (which leaves you with still a single display)
  6. krishna_gopal_2
    krishna_gopal_2
    4
    May 12, 2013
    Fine :cool:
  7. Six_Shooter
    Six_Shooter
    98
    Nov 16, 2012
    On at least two of my MoBos, I've been able to use both the onboard video and a video card to have dual monitors working. Using Win XP or Win 7.
    That being said, most video cards have dual monitor outputs anyway, so to improve system performance, I would disable onboard video and use both outputs from the video card.
Similar Threads
Loading...
