Hello guys, I had a question that maybe enough people could help with. About two years ago, I bought a portable 7" dual-monitor portable dvd system for my suv for my kids to watch movies and stuff on. They work great, but now that we have an in-dash dvd player in our vehicle, I want to mod the screens to work with the new dvd player. (It has RCA output).
Currently, the way the system works, there is one monitor with a power source and an RCA input (coming out of the controller on the other lcd screen). The main unit has the dvd player built into it, and the incoming 12v power source from the cigarette lighter. When the main one is on, it sends the power and video signal via rca and a dc jack plug to the other monitor, and they mirror.
What I want to do, is modify the first one so it no longer uses the dvd player, and accepts input just like the other monitor does, so I can run a couple of RCA cables from the main head unit to each monitor to mirror both screens. I took both of them apart, and the LCD screens are exactly the same, the only difference is the controller cards they plug in to. So now my question is, is there currently a circuit board that is pre-assembled, or schematics to assemble, that accepts one RCA input and splits the video into multiple LCD outputs that a normal 7" LCD screen can connect to ? I looked up the LCD screens online, and they appear to be some generic chinese ones, but the connector isn't proprietary. (It uses a standard ribbon cable for the display, and a smaller ribbon cable for the backlight).
If there's not a circuit board that's already designed to do this that I can just plug in, would it be possible to take the current main circuit board that is doing RCA out to the other monitor, and reverse the direction so that it accepts RCA input instead?
If you guys need pictures of the circuit boards or anything, i'd be happy to take some and send them to you, I just wanted to see if I could reuse these screens instead of buying two new ones.
Any help would be appreciated, and I thank you.
EDIT: In case anybody was wondering, the LCD screen on both units is A070FW00 V7
(Im wondering if I can just make a new simple pcb like the one from the input-only unit for the second one, it doesn't look very complicated)
