A
Andy Hunt
Hello all -
I live in Manchester, UK, and my home heating system is currently a wet
central heating system running off a natural gas non-condensing combi
boiler.
I'm planning on re-jigging the house to reduce my dependency on
non-renewable resources, which will include a solar thermal system (which I
hope will give me around 70% of my hot water annually) and a domestic wind
turbine (giving me 15% of my electricity, enough for lights and a couple of
appliances).
I have a gas fire in my living room, but I'm considering removing it,
getting the chimney sorted out, and replacing it with some sort of solid
fuel fire. The chimney goes up through my bedroom upstairs, so some heat
would reach that room if I had a fire downstairs.
I'm considering what I would need in the way of a solid fuel fire if, for
example, my gas supply got cut off. It would be nice to be able to cook with
the solid fuel fire, maybe with iron "ovens" either side of it, and also it
would be nice to have a "back boiler" fitted so that I would be able to
connect it to my wet central heating system (hot water taken care of by
solar thermal system).
I suppose my question is, (along with what solid fuel fire would be best),
would it be possible to connect a back boiler up to my wet CH system to run
in tandem with my gas boiler, so that I could easily switch between the two?
I was thinking of using wood (carbon neutral) or pellets or something for
the solid fuel fire, or possibly just smokeless fuel as I'm in a town. I'd
rather use something that was carbon neutral.
Any suggestions appreciated!!!
Andrew
boiler.
appliances).
Andrew
