Dual battery system
Discussion in 'Boat Electronics' started by Louis News, Aug 4, 2004.
  1. Louis News
    Louis News Guest
    Hi
    I hope this is the right newsgroup. Can anyone help me with schematics or
    plans for building a dual battery system for a 12v refrigerator running from
    a car and the battery system?
    You can mail me at
  2. Google is your friend, don't expect others to do your research on such a
    basic and common subject !!
  3. Yes. They should both end up charged.
    Ideally, batteries that are regularly used in parallel should be of
    the same make, type, vintage, and usage history - even then you should
    occasionally test one battery at a time, as the good battery (or
    batteries) in a bank can hide a faulty one.
    Peter Bennett, VE7CEI
    peterbb4 (at) interchange.ubc.ca
    new newsgroup users info : http://vancouver-webpages.com/nnq
    GPS and NMEA info: http://vancouver-webpages.com/peter
    Vancouver Power Squadron: http://vancouver.powersquadron.ca
  4. Jeff Morris
    Jeff Morris Guest
    This is true if they are discharged in parallel, but its not a problem when
    charging.
