DTMF decoder interfacing with microcontroller - required for robotics control
Discussion in 'Microcontrollers, Programming and IoT' started by pawankumaarv, Oct 6, 2009.
  1. pawankumaarv
    pawankumaarv
    Oct 6, 2009
    Hi there, I need to control robot through DTMF decoder
    so please help me in interfacing with microcontroller
  2. rushi53
    rushi53
    10
    Aug 19, 2009
    please explain in detail,
    this information is not sufficient to describe your project aim
  3. pawankumaarv
    pawankumaarv
    Oct 6, 2009
    My robot will move inside a room.... and it has to be controlled through wireless control.... for this I have decided to use FM or Mobile device.... and on the receiver side(robot) I will use DTMF decoder.... now depending upon DTMF codes, robot should move forward/reverse/left/right/stop...
    Please let me know if I need to give more explanation...
  4. rushi53
    rushi53
    10
    Aug 19, 2009
    If you want to go for DTMF controlling then you can use mobile. This will reduce the cost of transmitter section.
    Connect the headphone output to the DTMF decoder.
    Then give 4 pin output of Decoder to the microcontroller.
    Go through the datasheet of MT8870.
  5. sreeraj
    sreeraj
    Dec 17, 2009
    MT8870 IC decode the input dial tone to 5 digital output. These digital bits can be interface to a computer or microcontroller for further application
