DSC832 Trouble light
Discussion in 'Security Alarms' started by Guest, Jun 22, 2004.
  1. Guest
    Guest Guest
    Why is it that I arm my system fine, leave the premises, and when I return,
    the system is beeping for my code, but the trouble light is on? (LCD5500
    keypad).
    The trouble light was not on when I left.
    Michael
  2. Guest
    Guest Guest
    Doesn't help...
    Here is the step by step...
    Enter the house, kypad starts beeping to disarm...approach keypad and see
    trouble light is on, and display shows time and date.
    press any key and it prompts "Press * for System" and the trouble light goes
    off right at the same time. I press * nd then the acess code and the system
    is disarmed with th message "no alarms in memory"
  3. Mark Leuck
    Mark Leuck Guest
    Check the event buffer
  4. Guest
    Guest Guest
    The only thing that it says is "System" which is helluva descriptive!
