E
Eli
I have a DSC PC3000 that functions normally except the "Trouble" light
is on. The complaint is "Fail to communicate" and this problem started
with the 15-hour power blackout we experienced last August. However,
there is no problem with the communications. The monitoring station is
receiving everything (false alarms, weekly test) normally.
If you try *2 to verify the trouble,(code 5) the "Trouble" light goes
off. However, a couple of minutes following arming the system, a
single beep is heard every couple of minutes (I reset it by touching
any key). Upon disarming the system, the trouble light comes on again.
Checking for codes shows the same code 5 and the trouble light goes
off. Two minutes later (with the system disarmed) the beep returns
until touching any key stops the beeping.
My alarm installer thinks that the PC board is faulty and needs
replacing and says that it has been discontinued.
Can you help?
Thanks for your time,
Eli
Can you help?
Eli
