DSC PC 1550 Beeping
I am trying to install and program a pc 1550, and when the unit is
powered up, the keypad will beep. I have been told the keypad I am
using is compatible, but I am not so sure. The panel is a pc 1500 rev
4m, and the keypad is a pc5000rk. The keypad is a 4 zone, but I only
need 4 zones on the panel. I am trying to get into program mode, and I
have done a hard reset, but I am not sure what to do here, any
knowledge would be great.
D
Doug L
I don't think the 500 keypad is compatible with the 1550
I believe that any keypad for the 1500/1550/2500/2550/3000 series of panels
is more or less interchangeable.
If the 500 keypad will work with any other panel its more likely to be the
1575 or possibly the 1555/5010 series.
Unless you are on a really tight budget I wouldn't even look for a
replacement keypad, just buy a new 1555 & keypad and be done with it, if you
are on a tight budget you may have more luck looking for a used PC500 board
rather than a 1500/1550 keypad..
Doug L
