C
chuck
I hoping someone can help me on programming this keypad. I just
replaced my LCD-5501z keypad with the alpha numeric LCD-5500Z keypad
on a DSC PC-1555 system. Everything went well with the change and
everything seem to be working. The only thing I'm have a problem is
with enabling the fire enable and panic enable keys on the keypad.
When I press both keys for over two seconds, nothing happened, this
was functioning with my old keypad. I've look thru the install manual
for the PC-1555. In appendix B, its the section for programming LCD
keypad, I tried to follow along but it doesn't match up. There a
[64]key option for Fire keys enable and Panic key enabled. I tried
the following sequence:
* 8 {installer code}
064
When I put it 064, it beep as a invalid code. I'm I doing something
wrong???
I would appreciate any help, I've tried everything..
064
wrong???
