DSC 632 "general system supervisory" trouble
Discussion in 'Security Alarms' started by John D, Jan 9, 2004.
  1. John D
    John D Guest
    I'm having a strange problem with a self-installed (and self monitored
    via pager) DSC 632 (PC1555MX).
    I've got a LCD5501Z32-433 keypad connected. I have 2 zones only, both
    are wireless contacts. I'm using two wireless keyfobs, and have it
    set up to page me.
    Everything works great - for a while.
    After time, I get a general system supervisory trouble. (*2 1 shows
    5, general system supervisory). The wireless contacts stop working
    ususally at this point also. I get a page indicating the same, (which
    i set in section 348, #8).
    When hear it start beeping and see a trouble 1 - 5, I've checked my
    module enrollment (using section 903) and see 1, 17. (1 keypad, 17
    5132 wireless in keypad).
    If I do a 902 and wait a bit, then press and hold 'reset', it seems to
    function again for a while but eventually this problem repeats.
    There's nothing else connected to the pannel (except a siren and EOL
    resistors) and it keeps doing this.
    I've tried the following:
    1 - Testing wireless contact placement, almost always get a 'good'
    signal.
    2 - Reseting the panel (by shorting pgm1 and z1) etc\
    3 - Have reset the 5132 (using section 996)
    4 - Want to reset the keypad, but can't find info on how
    5 - 902 and a 'reset'. This corrects the problem but it comes back!!
    I'd really appreciate some help - I don't know what to do next.
    More details:
    Zones in Panel (1 - 8) have EOL resistors in them, not sure if they're
    needed. The keypad zone also has an EOL on it.
    Zones Types:
    00 - 09 : type 00
    10 : type 01
    11 : type 03
    12 - 32 : type 00
    Zone Attributes:
    All zones no attributes set, except for
    10 : 1, 2, 3, 6, 8
    11 : 1,2, 3, 4, 5, 6, 8
    Zone Assignments:
    all off (1 - 32) except for zones 10 and 11 (ie #2 and #3 in section
    203)
    Keypad Enrolment (section 000, 0):
    Slot 11
    Wireless Expansion (section 804, 10 and 11):
    All set to zero, except
    10 : XXXXXX
    11 : YYYYYY
    Where XXXXXX, YYYYYY is the ESN of the contacts.
    Supervison (section 804, 81 and 82,83,84,85):
    81, wireless supervisory window set to 32
    82,83,84,85 Zone device supervison options
    All set to Off, except 83 #2 and #3 (for zones 10, 11).
    RF Jamming (804 93)
    Set to 00
  2. TH
    TH Guest
    Go to section 804 and then section 90 turn option 7 on. Very common problem
    with DSC wireless recievers. Option is to disable RF jam detect. Manual
    shows that option is enabled from factory but I have found only on the
    latest ones it is.
  3. John D
    John D Guest
    It's got a tamper switch on the back, and it's got a metal springy
    thing that presses the switch in when the keypad is mounted against
    the wall.
    It doesn't seem to be this switch causing the problem, it generates a
    different trouble when I press/release it.
    John
  4. John D
    John D Guest
    Thanks I'll try that.
