C
Chris Carlen
Greetings:
I am using this TXCO in my Nixie clock. I was monitoring the current
flow from the battery backup on my newly completed PCB, when I happened
upon very infrequent large current pulse events.
Usually, the current load is about 10-15uA from the VL2320 battery when
the TCXO and AVR CPU are running from the battery (AVR in power-save
sleep mode except for 2Hz interrupts taking about 60us to service from
asynchronous timer2 compare match used to maintain the time).
But I found that every 64.1 seconds there is a 400uA pulse lasting
almost exactly 100ms. At first I thought the period was exactly 64.0s,
but then on a closer look, it appears to be 64.1. Not exactly sure
though, as the scope can't do delayed trigger beyond 50s, so I can only
get a cursor measurement, which on a single shot 100s capture only has
0.1s resolution.
The 64s originally made me think some strange program bug was occurring,
like the another interrupt waking the CPU. But I also suspected that
maybe something in the TCXO might be responsible. I went back to the
breadboard so I could measure the TCXO vs. CPU currents separately, and
discovered the CPU was hovering around 11uA average like it should, with
no current pulses every 64s.
Sure enough, it was the DS32kHz. It appears to do something every 64s
or so, that uses 400uA, then it goes back to its usual 4uA draw from the
Vbat terminal. It is most likely the temperature compensating
mechanism, as the datasheet states "...periodically measures the
temperature and adjusts the crystal load to compensate."
Well, that period is about 64s and the important thing is the TCXO pulls
400uA for 100ms.
Just a heads up to DS32kHz users. I suppose some battery backup
circuits designed with the expectation of 4uA continuous, could hiccup
on the 400uA pulses. It also means an extra 0.625uA of average current
is really present which one might not see if measuring with a meter
only. Fortunately none of this is a problem in my circuit.
Good day!
0.1s resolution.
400uA for 100ms.
Good day!
