Sam said:
There's usually a spring loaded tensioner (which BTW, one should treat
with respect as it has sent people to the ER).
It's not clear what his problem really is though.
--- sam | Sci.Electronics.Repair FAQ:
http://www.repairfaq.org/
Repair | Main Table of Contents:
http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ:
http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites:
http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
Almost every dryer I've seen (maybe a dozen...I'm no appliance
repairman) has a hinky little tensioner which sits on the bottom of the
dryer. It's held in place by a couple of tabs and the tension of the
belt. Without tension, the piece falls into the bottom of the dryer.
I've always put everything in place: belt, tensioner, motor, drum; then
held the drum up through the dryer door while I replaced the
front...being careful not to crimp or dislodge the felt gasket. It's a
juggling act, but unless there's an access panel below the dryer door
(rare, but I've seen that); I can't imagine any other way to do it.
BTW, the threading procedure for that tensioner really threw me the
first tried to do it. I had to search high and low for a diagram for it
all to come together in my mind. Briefly, the belt goes around the drum
and the loose slack is passed *through* a slot in the tensioner and then
around the motor pulley. For the life of me, I couldn't figure it out....
There must be other motor/belt/drum schemes, but this is certainly the
most common, IME.
jak
jak
