W
Watson A.Name - Watt Sun, Dark Remover
I read in alt.binaries.schematics.electronic that Watson A. Name - Watt
[email protected]>) about 'Dropping 1V from a Regulated 6V
Wall Wart', on Wed, 31 Dec 2003:
That's a coaxial connector, a bit like a phono plug but with a smaller
centre pin. Is that what you have?
I'd forget those descriptions if I were you. Certainly the Belling
connector has very little indeed to do with PAL. It is the subject of an
IEC standard - IEC 60169-2.
Yeah, but here in the U.S. you go to Rat Shack and buy a Euro or PAL
adapter, shove it in the socket, and forget about it for the rest of
the life of the equipment. Everything else is done with F connectors,
so it's not really an issue. In fact, I may heat up my big 100W
soldering iron and make the adapter a permanent part of the equipment.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
