DRO Mitutoyo AT11-series; attach connector to cut-off wire.
Discussion in 'Electronic Repair' started by [email protected], Apr 18, 2007.
  1. Guest
    A while ago I have been given a digital readout system for the lathe
    (DRO) from Mitutoyo, with AT11 series linear scales (rulers).
    It needs a bit of work done though, mostly because the connectors have
    been cut off from the linear scales. After a bit of research on the
    net it appears it needs a 6 pin round connector, but the hardest part
    is to figure out which wire goes to which pin. I don't have the
    original connectors anymore either so I can't work back from them.
    Very little info is available on the net.
    I was wondering whether anyone in here had any technical information
    (esp. w.r.t. wiring the rulers) on the Mitutoyo AT11-N100 and AT11-
    N350 scales with 6 pin round connector.
    I'd greatly appreciate any help on the subject.
    Regards,
    Peter Dingemans,
    The Netherlands.
  2. Mike Berger
    Mike Berger Guest
    Post this to rec.crafts.metalworking and you'll probably find
    someone with the information.
