Driving two motors using a single current driver
Discussion in 'Sensors and Actuators' started by Nima Najmaei, Aug 3, 2014.
  1. Nima Najmaei
    Nima Najmaei
    Aug 3, 2014
    I want to drive two motors, and I have just one current driver/controller. I want to activate one motor when I have a positive polarity in the current generated, and activate the other motor when the polarity switches to negative.
    So:
    Positive Polarity: Motor 1 (ON) Motor 2 (OFF)
    Negative Polarity: Motor 1 (OFF) Motor 2 (ON)
    Can you help me on how to do this? Any ideas?
    I know we can use diodes to do that, but is there any more reliable and professional way to do it. Please help a clueless Mechanical Engineer.
  2. KrisBlueNZ
    8,393
    1,268
    Nov 28, 2011
    Hello and welcome to Electronics Point :)
    The diagram you've drawn should work fine.
    I don't think you'll need diodes across the motors to suppress the back EMF because each motor/diode pair will suppress the back EMF of the other motor.
    It might be more "professional" to use two separate drivers, but I think that's a fair solution.
