Driving LED with NPN
Discussion in 'LEDs and Optoelectronics' started by Gr0zn1, Feb 21, 2014.
  1. Gr0zn1
    Gr0zn1
    3
    Jan 17, 2014
    Hello!
    I have a question about driving LEDs using NPN transistor.
    I've made square signal generator that works at 10Hz and 25:75 duty-cycle and on 5V. With that output I would like to drive the base of NPN 2N2222. Let's say I would like to drive 6 LEDs with typical Vf=2V at 20mA. I would like to know the right values for base and LED resistors, if I use a secondary supply for LEDs with 30V.
    Thanks for your help!
    Gr0zn1
  2. (*steve*)
    25,482
    2,830
    One place to start would be here: https://www.electronicspoint.com/got-question-driving-leds-t256849.html
    Use a series resistor as if they are being powered from the 30V supply. Have the transistor's emitter grounded and use a base resistor which is about:
    0.5 * (Vin - Vbe) * hfe / Iled
    For hfe use the lowest value specified in the datasheet for an Ic near 20mA.
    If it's 100, the resistor would be about 0.5 * (5 - 0.7) * 100 / 0.02 = 10,000, so 10k would be fine.
