P
Peter S. May
The original question about single outputs has been answered, so I'm
moving on to focus on this problem.
I've done at least some looking for transistor arrays that come in
eights and have common emitters, and so far the only real results that
have turned up are the CA3251, which is apparently way out of
production, and the ULN2803A Darlington array. Using an array with
common emitters would simplify things, as would having built-in base
resistors, and the ULN2803A is a go on both.
The objective is to map each of eight outputs on a 74HC chip or PIC to
the light of ten high-brightness LEDs, Vf of 3.2~3.6V, at 15~20mA. (In
the case of using ULN2803A I would use two of them, driving 5 LEDs at
each output.)
My original idea was to have the transistors sink the cathodes directly:
+5V <------+-+-+-+- ...
V V V V LEDs
74HC output |/---------+-+-+-+- ...
--->o------------| 1/8 ULN2803A (oversimplified)
|\>---|GND
Then I found out that I have no real information regarding what the
collector-emitter voltage would be at any given moment, but that the
data sheet suggests one possible value is 2V, which is too little margin
for me to work with.
The next idea was to run the Darlington as an inverter, inverting the
inputs accordingly (probably at the software level if applicable).
+5V <----+
+--/\/--->|--+-|GND
------->o---------------|
|\>---|GND
Is this alternative a reasonable design? Should I be looking at another
transistor array (-like device) instead?
PSM
each output.)
V V V V LEDs
|\>---|GND
+5V <----+
+--/\/--->|--+-|GND
|\>---|GND
PSM
