P
Piglit
Trying to devise a way of efficiently driving a phone amplifier off a
48 volt phantom powered mic line. The acitve lines (2) are current
limited typically by 6k8 resistors, and allowing for an additional 1k
on each leg to bridge into the amp, that gives around 12ma short
circuit, 6ma at 24 volts - the point at which maximum transfer power
is available. I would like more current and less voltage (Nat Semi etc
have some nice efficient little class D amps that work on 5 volts that
are ideal for driving headphones). Hence I need a DC/DC converter. The
problem is that all the buck regulators in the TI, Nat Semi offerings
loose efficiency drastically below 100ma or so, thus defeating the
purpose of the exercise. None of the switchcap regs work at 24 volts.
Any other suitable devices out there ?.
M
M
