driveway heater
T
Tanya
hi,
this is pretty vague --
it is a 30 y/o driveway heater (to melt snow) that turned on
spontaneously for the summer.
the power switch (for the user) was in the off position however
<apparently> it is (was) controlled by an inhibitor of some sort which
broke.
question: could a power surge (for example after a power failure) damage
the <an> inhibitory item and cause it to malfunction (or not function)?
apologies again for being vague
thanks
S
Sam Goldwasser
Tanya said:
hi,
broke.
thanks
Right, a bit vague but certainly a power surge could damage a switch,
or could have been something else. Next time, make sure the breaker
or actual physical switch for the device is off in the summer! :)
--- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
Important: Anything sent to the email address in the message header is ignored.
To contact me, please use the feedback form on the S.E.R FAQ Web sites.
T
Tanya
thank you very much for the reply!
it is a power-hungry monster.
the switch (the user's switch) and the control-box switch were off however the
breaker (in the fuse box) was not activated
sincerely
Tanya
