DPDT relay wiring
Discussion in 'General Electronics Discussion' started by mikgol, Mar 27, 2016.
  1. mikgol
    mikgol
    87
    Jul 6, 2013
    Hi there,
    I have one of these relays ...
    http://www.adelaida.ro/releu-auto-12vdc-30a-v23084-c2001-a403.html
    ... it looks like there are 2 coils (11/12 & 21/22) - I want to use this relay to drive a motor backward and forward. Should 21 & 11 be connected together, and 22 & 12 be connected together? I want to control it using and arduino
    Thanks for ur help
  2. Bluejets
    Bluejets
    4,658
    984
    Oct 5, 2014
    Looks like it is 2 relays in the one casing.
    Had a peek at the spec sheet and it says double mini relay.
    You could verify it by powering one coil and use a multimeter to check the contact closure.
    So for your motor you would energise one coil for forward and one coil for reverse.
    If using with a microcontroller don't forget diodes across the coils and some interface (transistor or mosfet) to drive the coils as they are 12V.
    Make sure you include some sort of interlock between the 2 so both cannot come on together.
    Wiring for the motor would be the same as I put here a few days ago.
  3. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    There is a trick you can use that is employed in most automotive window/lock installations.
    Pins 25 and 15 go directly to the motor.
    Pins 24 and 14 go directly to ground.
    Pins 23 and 13 go directly to Vcc (Power)
    That is the high power side and will ensure that even if you try to trigger forward and reverse at the same time, you won't break anything ;)
    Neutral, both wires held to ground. Motor will 'brake' and resist motion.
    Forward, motor + wire connects to Vcc. Motor will move forward.
    Reverse, motor - wire connects to Vcc. Motor will move backward.
    For + Rev, motor + and - wires connect to Vcc. Motor will 'brake' and resist motion.
    From here, it's up to you to determine how you want to drive the coils on pins 21/22, and 11/12.
  4. mikgol
    mikgol
    87
    Jul 6, 2013
    Thanks very much for your help guys. I'll give that a go. I don't get too much time on my electronics hobby unfortunately, so I work on my projects in dribs and drabs when I find the time (this relay is for a project I started months ago) - ty for sharing your expertise :)
