I have been looking for a DPDT red push button momentary switch for use in an application of mine and can't seem to find that exact thing. Should I use a Relay?
The application is:
I need the ONE switch to be able to operate two motors. One motor needs to be on (NC connection) and the other needs to be off (NO connection) in the normal state of the switch.
When pressed the motor that is on goes off and the motor that is off comes on.
I have found expensive switches from places like Grainger that comes with contact blocks you can assemble in pretty much any way. But I wanted a switch that costs less than $50 though.
Any help?
The application is:
Any help?
