doubt in active device
Discussion in 'General Electronics Discussion' started by bhuvanesh, Apr 13, 2014.
  1. bhuvanesh
    bhuvanesh
    201
    Aug 29, 2013
    Code:
    Those devices or components which produce energy in the form of Voltage or Current are called as Active Components
    how diode produce power
  2. (*steve*)
    25,382
    2,771
    No active devices do not produce power.
    Power supplies (or their theoretical models -- voltage and current sources -- do that).
    A diode when exposed to light produced power by the photoelectric effect. But that's it acting like a power supply. I'm sure this is not what you meant.
  3. bhuvanesh
    bhuvanesh
    201
    Aug 29, 2013
  4. davenn
    davenn Moderator
    13,580
    1,868
  5. Harald Kapp
    10,025
    2,138
    In the link you refer to it states:
    I'd say: forget this assertion. It is nonsense. Steve explained it correctly.
  6. bhuvanesh
    bhuvanesh
    201
    Aug 29, 2013
    what does mean that active devices produce energy in form of voltage or current
  7. KrisBlueNZ
    8,393
    1,268
    Nov 28, 2011
    It means that the person who wrote that page doesn't know what he's talking about and/or cannot express himself clearly.
  8. duke37
    duke37
    5,360
    765
    Jan 9, 2011
    It depends on what you mean by produce.
    Thermodymics says 'energy can neither be created or destroyed'
    The best an active device such as a transistor can do is to control the amount of energy taken from its input to its output, often with a lot of energy lost as heat.
