W
Winfield Hill
Does anyong know of any double-shielded optical couplers with higher
maximum output-slew-rate specs than the common wimpy 15kV/us rating?
Background:
Optical couplers are rated for a maximum allowed common-mode voltage
slew rate, which if exceeded may cause the coupler to malfunction
(e.g. the output may change state, etc.). A typical best-rated part
from a manufacturer like Agilent or Toshiba is rated at S < 15kV/us,
which means one could use the coupler to drive a high-side switch
limited to slower switching than say t = V/S = 42ns for a 630V swing.
While 40ns may be fast enough (even too fast) for large motor drives
or lamp ballasts, etc., for many applications it's very slow. While
one can solve the problem with optical-fibre links, or transformers,
etc., it would be preferable to use a single-package optical coupler
with appropriate internal double shielding for a faster slew rating,
like 250 or 500kV/us. That would be more like it!
Why double shielding? Generally one's first concern is maintaining
proper operation of the coupler's output in a high slew-rate scene.
If the photo-diode detector is operating on say 5uA of photocurrent,
then i = C dV/dt tells us that the inter-electrode capacitance C had
better be well under 0.33fF for a 15kV/us rating. That's the purpose
of the first internal shield. But at high enough slew rates, the LED
also needs a shield. E.g., Agilent's HCPL-3020 is rated at 15kV/us.
http://literature.agilent.com/litweb/pdf/5988-8736EN.pdf and its
LED-to-output capacitance is 0.6pF. When this part experiences a
15kV/us output slew, the induced current into the LED is 9mA, which
approaches the standard 10mA LED drive current. Clearly without an
input shield the part cannot withstand a higher output slew rate,
and one wonders if even 9mA of parasitic current is acceptable.
That's why I'm looking for some double-shielded optical couplers,
hopefully with _much_ better specs than 15kV/us.
- Win
Background:
- Win
