Double grounds and Double positives
Discussion in 'General Electronics Discussion' started by bluemarshall, Jun 14, 2012.
  1. bluemarshall
    bluemarshall
    14
    May 30, 2012
    I've recently seen posts in other forums that refer to double grounds and double positives? Can anyone explain what these are what the benefit of using them would be?
  2. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Really a loaded question, can you point to the circuit in question?
    Lots of times you will have an analog ground and a digital ground so that you can reduce interference...
    And many times you have two positives at different levels, so you can run devices at different voltages...
  3. donkey
    donkey
    1,300
    56
    Feb 26, 2011
    just to add to coca cola there are times when a design is way to big too connect all the positives together so you can find a few places that have grnd or pos listed. if the voltages are the same and it does not refer to one being digital or analogue you can infer these can be hooked up to the same power source.
