Door bell and camera problem
Discussion in 'General Electronics Discussion' started by Tonyle59, Mar 4, 2018.
  1. Tonyle59
    Tonyle59
    3
    Mar 4, 2018
    I’m a beginner of electronic, need to learn a lot. I know I can hire some one to do it, but this is very interesting project I would like to learn.
    My door bell power supply is 18 volt DC. and my camera is power up with 12 volt DC. how can I use them together ?
    Thanks all for helps
    Tony
  2. Kabelsalat
    Kabelsalat
    160
    29
    Jul 5, 2011
    Your door bell is probably feeded from a spechial transformer, that is AC voltage - so there will be two separate systems.
  3. Optionidus
    Optionidus
    Mar 4, 2018
    What is the brand name of your Camera doorbell?
  4. Tonyle59
    Tonyle59
    3
    Mar 4, 2018
    First thank for your supported
    My door bell name is Skydoorbell. And the old one is AIPHONE JF -2ME
    I want to use both cause sky bell can connect to iPhone aap and the other is not and it have monitor in the House only.
  5. Nick Lee
    Nick Lee
    9
    Mar 4, 2018
    do you want to power them both from one power supply?
  6. Tonyle59
    Tonyle59
    3
    Mar 4, 2018
    Hi
    Yes. But the old one is supply by 18 volt DC 2Amp.
    The new one need only 12 volt.
    Please advice.
  7. Tha fios agaibh
    Tha fios agaibh
    2,166
    726
    Aug 11, 2014
    Tell us the amperage or wattage ratings of the bell and camera.
    You may be able to use your18vdc power supply to feed the doorbell and tap off of it with a Lm7812 regulator to feed your camera.
    Current ratings are rather important, unless you don't care if the camera drops out when someone rings the doorbell. :D
