P
Paul G.
I was trying to make my own sound level control circuit (which I
did) and in the process discovered that Dolby has a very good sounding
sound processor
(http://www.dolby.com/consumer/technology/dolby-volume-demo.html) that
is often incorporated into several digital media control units, and is
also built into some CirrusLogic audio DSP chips
(CS48DV2A-CQZ,CS48DV2B-CQZ,CS48DV6B-CQZ,CS48DV2A-DQZ). There are also
evaluation boards (CRD48DV2-USB 2ch., CDB48DV6-USB 6ch.). The
evaluation boards looked very interesting, since they had analog
inputs and outputs. The ADC and DAC functions were built into the
evaluation boards. The other chips above, accept digital I/O.
Apart from the rather high cost for the evaluation boards ($250-300)
they seem difficult to obtain, it looks like these are special factory
orders, with minimum 26 week delivery times. The chips aren't all that
costly 10-20$, but require orders of 2000 min, with poor delivery
dates. The chips seem a messy solution, since they require a lot of
supporting hardware and software.
I was looking for an analog box to go between a digital cable box
and a TV set. The inconsistencies of loudness between channels and
programs was driving me nuts - I couldn't hear soft conversations in
movies, and was blasted out of my chair by commercials. Even though
the cable box provided some degree of compression, it was not enough
to overcome the "mucking about" some channels have done to their
audio.
My home-made kludge allows me to apply a +10db extra gain for low
levels, and a 10db attenuation for loud levels. Both have threshold
levels that I can set from -60dbv to +20dbv. This doesn't have any of
the whizzy frequency bands and masking compensation that the Dolby
Volume processor has. It does finally let me watch the old movies
without waking up half the neighborhood.
I'm intrigued by the Dolby Volume..... has anyone tried one of
these? It's being added to some of the more recent AV products (i.e.,
Arcam AVR600, Harmon Kardon AVR1600). I don't see any products that
are cheap and simple, something that you could buy for less than $50
and stick it between your sound source and stereo in analog form.
There is probably a reasonable market for such a thing, I have heard
many complaints about the excessive variation in sound levels from TV
stations.
I did find this unit available in the UK for 60 pounds:
http://ukhdmi.com/CYP_DCT_6_Dolby_Volume_Processor_QQ101641 but it
seems impossibly small to house all the circuitry required!
There is other competition to Dolby Volume, that is: "SRS
Truvolume", and "Audyssey Dynamic Volume". All use DSP. I couldn't
find any sources that would allow me to do a DIY circuit using them,
other than purchasing another impossibly small unit like the above
one, but using "Truvolume", from the same manufacturer.
Grrr..... electronic technician's dilemma.... pay $100-150 for
pre-packaged unit, or build it myself for about 1/2 the cost in parts,
several hundred hours of fiddling, months of delivery delays.....
How difficult are these audio DSP's to use and breadboard?
Paul G.
sound processor
audio.
stations.
Paul G.
