Does this look right?
Discussion in 'Electronic Basics' started by [email protected], Dec 22, 2005.
  1. Guest
    I made a simple circuit in "Electronics Workbench" and the amp meter
    reports over 8A across the resistor. I thought the amps would be very
    low across a resistor in this kind of circuit. See link to image
    below.
    http://216.46.248.210/memberserv/upload2.asp
  2. Guest
  3. What are the size of the resistors?
  4. Guest
    1.44ohm and .321ohm left to right.
  5. Lacy
    Lacy Guest
    No where near correct.. .You can not measure current across the resistor.
    You need to put the ammeter in series with the circuit. The current will be
    the total current flow in the circuit since it is a series circuit. Current
    is the same in all parts of a series circuit.
  6. Guest
    That's what I thought. So the program is lying to me. He he and they
    want over $2000 to license it.
  7. Dave
    Dave Guest
    Actually your circuit is designed wrong to check current here... take the
    amp meter off of where you have it and but it between the positive lead of
    the battery and the first resistor .... you will actually "break" the path
    (wire) between the battery + and resistor and put the amp meter in its
    place... amp + to the positive side of the battery and the Amp - goes to the
    resistor... in a series circuit the current remains the same throughout the
    whole circuit (both resistors will have the same current flow...
    You have your meter is Parallel... needs to be in series..
    Adding your resistors together ( 1.44 + .321) <-- I take this is point 321
    ohms... this will give you an RT of 1.761 ohms
    Ohms law states V/R=I ... in this case it would be 12v divided by 1.761 =
    6.814 amps
  8. Lacy
    Lacy Guest
    No the program is not lying. Your configuration is incorrect. The ammeter
    needs to be in series with your circuit. Check below and try it.
    - -----1.44 ------ 321 --- Ammeter ----|
  9. No. The program is telling the truth. The ammeter's resistance will
    be very low (probably zero in the simulator), so you effectively have
    1.44 ohm resistor across a 12 volt battery. By Ohm's law, the current
    through the resistor should be 8.333 amps.
    What you need to do when measuring current is break the circuit, and
    insert the meter in the break. If you do this, the meter should read
    about 6.814 amps.
  10. Guest
    Yeah but shouldn't the ammeter read 0 amps or near zero when connected
    the way shown?
  11. Guest
    So the ammeter becomes a 1.44 resistor?
  12. Please quote some of the message you are replying to, so we can see
    what you are talking about. (most of us don't use Google Groups, and
    our newsreaders will only show one message at a time.)
    In Real Life, the resistance of an ammeter is very low - probably
    under 0.05 ohms, however, I would expect the simulator's ammeter to
    have a resistance of zero.
    If the meter resistance is zero, and you have it connected across your
    ..321 ohm resistor, the only remaining resistance in the circuit is the
    1.44 ohm, so the current in the circuit is 12/1.44 = 8.33 amps.
    By the way, Linear Technology has a very nice free simulator called
    "LT Spice" available for download.
  13. No. Since it is in parallel with the .321 ohm resistor, the total
    current in the circuit will divide between the .321 resistor and the
    meter, in inverse proportion to their resistances. The simulator
    meter probably has a simulated resistance of zero, so all the current
    will flow through it, and none through the .321 ohm resistor.
    In Real Life, the meter will have some resistance (my Fluke meter is
    0.04 ohms on the 10 amp range). In that case, some current will flow
    through the .321 ohm resistor, but most will still flow through the
    meter - by my calculations, you would have about 6.6 amps through the
    meter, and 1.7 amps through the .321 ohm resistor.
  14. Guest
    Yes the meter is set to 1nm. I forgot that electricity will take the
    path of least resistance so with the ammeter resistance being near 0 it
    simply allows the current to bypasses the .321 resistor leaving only
    the 1.44 in the circuit.
    Thanks for clearing that up.
  15. DSallee
    DSallee Guest
    nope... it just checks the current..... has no effect on the circuit
    itself....
    Here is how the circuit and amps SHOULD look for the circuit and I also
    added 2 more meters hooked up like you have (across the resistors).. they
    are to check voltage drop across the resistors... not current.... like
    this......... www.audiopulse.net/amptest.jpg
  16. Guest
    I went to their web site but didn't find LT Spice. Just some other
    programs that didn't look like sims.
  17. Pooh Bear
    Pooh Bear Guest
    It's teling you what the current is through a 1.44 ohm reistor with 12V
    applied.
    The answer is correct. The ammeter 'shunts out' the second resistor.
    You can't wire up a circuit.
    You don't get amps *across* a resistor.
    You're an idiot. Go learn something about Ohms Law for starters.
    Graham
  18. Pooh Bear
    Pooh Bear Guest
    No !
    Stop making a fool of yourself and learn something about current flow.
    Graham
  19. Guest
    There's always one of you stupid mother fuckers on these NG huh?
    Calling someone an idiot without any real knowlege of their own. My
    guess is you don't know anymore about electronics than I do. In fact
    you are probably not intelligent enough to learn so you just spew
    insults. Typical huh?
  20. Guest
    Yep, pooh is what you are full of so I guess at least your name fits.
