Does this blown fuse come out?
Discussion in 'Troubleshooting and Repair' started by BPmax, Feb 1, 2011.
  1. BPmax
    BPmax
    9
    Feb 1, 2011
    Can anyone explain how to remove this fuse?
    My wife brought home this x-acto pencil sharpener and said fix it. er, OK.
    I found this blow fuse, but knowing nothing about circuit stuff, I have no idea how to get it out
    Does the whole fuse with stems come out, then re-solder a new one in? Where would I get one?
      File size:
      101.7 KB
      1,332
  2. (*steve*)
    25,482
    2,830
    You remove it by un-soldering it, then you solder in a new one.
  3. BPmax
    BPmax
    9
    Feb 1, 2011
    Ah ha! Thanks.
    Where would I find such a fuse? How do I ID it?
  4. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    The end caps (the ones with wires) can be pried off from the rest of the 5 x 20 mm (european) fuse, then you can just press in an ordinary fuse, without soldering.
    Depending on size tolerances you may have to crimp the end caps slightly though to make them grab the new fuse tightly.
    One of the end caps of the fuse itself will have the value imprinted. The important stuff is the number in front of the A, and if there's a T or an F there.
  5. BPmax
    BPmax
    9
    Feb 1, 2011
    The fuse reads 315A 250V
    Is there a similar fuse I can use as a replacement?
    Is the size 5x20?
    Slow or fast?
    Thanks!
  6. alfa88
    alfa88
    331
    4
    Dec 1, 2010
    Fast Blow
    A fast blow, 1/3 amp fuse will work. As stated before the end caps pry off. Since the fuse is already bad you could crush the fuse to ease extraction but take care not to break off those end caps or to get broken glass in your eyes. Pliers and needle nose pliers are your friends here.
