Does anyone recognise this symbol?
Discussion in 'General Electronics Discussion' started by ElectricBabe, Sep 11, 2014.
  1. ElectricBabe
    ElectricBabe
    6
    Sep 11, 2014
    Hello everyone!
    I'm new here and a bit of an electronics novice, so i need some help!
    Im trying to fix my Philips TV and have hit a bit of a 'roadblock' . The tv is getting no power . There are few caps blown but I think the problem is a small component next to the fuse.. The problem is I'm not sure what it is! It looks like a small resistor and the symbol is similar to that of a resistor but with rounded edges...not one I've seen before. Does anybody know what it is and where I can find a replacement?
    Joanne
  2. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Hi Joanne and welcome to Electronics Point :)
    Can you upload some pictures? The component and/or its circuit symbol?
    ElectricBabe likes this.
  3. ElectricBabe
    ElectricBabe
    6
    Sep 11, 2014
  4. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Got it. I'm not sure what it is either. Could be a thermistor. What does the component look like?
  5. ElectricBabe
    ElectricBabe
    6
    Sep 11, 2014
    A small resistor looking thing, but its transparent in the middle. Its arcing across when the power plug is plugged in. Does it being next to the fuse give any hints?
  6. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    No. Can you upload a photo of it?
  7. Harald Kapp
    11,522
    2,654
    Yep, pictures would be fine.
    Does it look like one of these:[​IMG]
    Then chances are it is a ceramic filter (see 1207 and 1104 here).
      File size:
      362.4 KB
      353
  8. ElectricBabe
    ElectricBabe
    6
    Sep 11, 2014
    Not until later, I thrust it upon my dad to take to maplins, to see if they had any idea, and he isnt back until later :(
  9. Harald Kapp
    11,522
    2,654
    Well, arcing doesn't sound like a ceramic filter, more like a fuse that has blown.
    Sorry I missed the part of the conversation before my post while I was googling )
  10. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Probably best to wait till then.
    It seems odd that the symbol looks like a resistor with an obround around it, it looks like a fuse or maybe a spark gap, and it's arcing. Doesn't sound like anything I recognise.
    Is there a circuit reference printed on the board beside the position?
    I'm going to sleep now but Harald will sort you out
  11. ElectricBabe
    ElectricBabe
    6
    Sep 11, 2014
    The symbol is like that, but with a ---/\/\/\/\/\/---
    In the middle :)
  12. ElectricBabe
    ElectricBabe
    6
    Sep 11, 2014
    The reference is RA8002 , thank you for your help :D
  13. davenn
    davenn Moderator
    13,837
    1,951
    That's commonly the symbol for a fusible resistor
  14. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    That seems like a good explanation Dave. The description doesn't really sound like a fusible resistor, but we will see...
    Joanne, what is the model number of the TV set?
    Can you post in-focus pictures of both sides of the circuit board in that area?
  15. Y2KEDDIE
    Y2KEDDIE
    259
    15
    Sep 23, 2012
    It may be a VDR (Voltage Dependent Resistor). Bascly a thermistor. Used for supressing power surges. It has a high resistance when cold and decreases as current flows though it. Try placing a 100 watt incadescent light bulb in the circuit in place of the device. Tthe bulb should light and the cicuit power up.
  16. shrtrnd
    shrtrnd
    3,821
    519
    Jan 15, 2010
    I can't say with certainty, but I'm with davenn on this. The oval circle is the generic symbol for a fuse, the resistor in the middle of it would indicate a fusible resistor to me.
    With engineers being trained us U.S. schools, European schools, and wherever the engineers are coming from for Pacific Rim products, it's hard sometimes to keep-up with
    whose symbols or combinations of symbols are being used anymore.
  17. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    The barreter has a oval circle and is not a fuse. I dont think we can make that assumption. It depends if you use IEEE or ANSI I guess.
    Thanks Adam
  18. davenn
    davenn Moderator
    13,837
    1,951
    that takes me back to the tube radio days !! :)
    not something you typically see or hear of in modern electronics
  19. (*steve*)
    25,497
    2,838
    It has been a long time since any of my cars had one either!
    More seriously, are they at all related to platinum RTDs?
  20. FirstSpear
    FirstSpear
    5
    Sep 13, 2014
    Howdy. Did a search for RA8002 and found this pdf
    https://www.epm.com.co/site/Portals...ecnicas/NORMARA8-002_revision2010_VFINAL1.pdf
    Yep it is in Spanish, but the title at the top of each page reads, "Current limiting resistors for the protection of transformers..." Corriente = current, fusible = fuse; much is readily translatable as the electronic terms are very similar to the English. It contains some photos, and a cutaway diagram of the internal makeup of the device. It does, though, deal with very high voltages, but given all the speculation about fusible resistors, it seemed worth the post.
    To muddy the waters further... The diagram presented in the thread is a schematic, and that outline resembles a crystal to me. Just saying.
