Does anyone know how the retracting mechainsm works on a (Nikon)digital camera?
Discussion in 'Electronic Repair' started by Amanda Riphnykhazova, Jul 15, 2013.
  1. A Coolpix S9300 was dropped on the lens when I had had it for n a week.
    The front metal piece containing the lens cover is severely dented and cameoff.But the rest of the camera looks fine. However the unit was left with the lens in the out position and wouldn't retract. (actually with a lot ofplaying with it, the camera works but the non-retracting lens now wont focus on the working screen.
    That piece cant cost all that much and must be easy to fit. It looks as if it just pushes on to the front of the forward cylinder. Has anyone any experience of this please and should I take it to a local repair shop which can buy the parts from Nikon if the repair is that easy?
    The problem, obviously, is that I have spoken to the shop and whoever answers the telephone there tells me that they send all Coolpix repairs of the slightest complexity back to Nikon (who will charge more than the $100 whichthe camera is worth to repair it)
    Does anyone know how these retractable lenses work please? There is a pin going into the lens which activates the lens cover. Does anyone think thatputting the front piece back on will suddenly activate the electronics governing the whole lens again please?
  2. Thanks Isaac for that very full reply. It seems possible to buy these cameras for parts very inexpensively on ebay at the moment and with August approaching, prices will go even lower. How difficult is it to switch out the whole lens assembly mechanism itself like Nikon would do if they did the repair?
    Back in the days when smartphones were a rarity, I replaced screens on Wings, 8525s and Wizards and that involved taking the whole phone down to the last screw! What I discovered was that everything is pretty modular and designed to let only semi-skilled third world workers compile these SORTS of things from modules.
    Or would the camera never focus to infinity any more if not adjusted with minuscule accuracy when completed? (or does that theory date from the days when film planes were fixed and no longer apply now that intricuate electronics designates when the camera is properly focused?)
  3. Charlie+
    Charlie+ Guest
    Thanks for posting that useful info, Ill look more closely at Panasonic
    when next after a camera! Just to add info for others I broke the
    screen on a Pentax Optio 5i compact (very small) and it was for the bin,
    so i took it apart - a nightmare once inside and I would say quite
    impossible to repair anything to do with the lens system (tiny
    beautifully made plastic click together parts with absolutely no
    provision for reversing assembly!) without spending hours and hours and
    with no guarantee of success! Also really buried inside was a tiny NiCd
    soldered in rechargable cell which was leaking - so these cameras have
    a time limited life anyway! This Pentax was 5/6 years old - the bin was
    definitely the right way to go!
    C+
  4. That's the advantage of junk equipment, you can learn from them. Since
    they don't work, it doesnt' matter if you damage then, but yo might get it
    going. But trying it on something yo don't care about yo may learn that
    it's not worth the effort on a good item.
    I dragged home an LCD monitor a couple of years ago, and when I plugged it
    in, it turne dout the screen had been cracked. So I stripped it down, and
    in doing so saw how accessible most of the electronics were. That
    prepared me for the next one I found, which did work, but reset
    sporadically (bad capacitors in the power supply). The LCD monitors are
    so easy to work on compared to CRT monitors or tv sets, the boards are
    small, and easy to access and remove, and everything is pretty available
    with the power on. The lack of high voltage for the CRT helps, too.
    As for the other batteries in digital cameras, that seems common. The
    flash on mine keeps turning on, when I keep turning it off, and that
    reminded me that it has some button cells accessible from the battery
    compartment, to keep something, presumably the settings, alive when the
    main batteries aren't in. I think a previous digital camera had some
    button cells too.
    Michael
  5. I agree with you and say that I have done this to intricate things like Smartphones. What I was wondering was whether it is easy or almost impossiblydifficult to take apart a 12MP digital camera. Or is everything very modular, - even if it can be impossible to repair modules themselves? Is anything on this camera likely to be easy to repair, - given how inexpensively they can be bought as repair units?
    I am a bit worried that the local camera repairer (who presumably has all the setup and calibration equipment he needs) says that he doesn't do ANY Coolpix repairs. He sends them ALL to Nikon who presumably replace the whole camera 'cos they charge approx the landed price of the new camera for any repair.
