G
Glenn
I just assembled a circuit which has a transistor to switch the coil on
a relay (driven from logic level of microcontroller). The transistor
is a general purpose TO92 package, 0.5 A switching type (like a 2N2222
or similar).
I had a problem with it that I've seen on odd occasions in the past.
Every now and then I seem to get a leaky transistor that doesn't shut
off properly. (I always have a diode in parallel with the relay coil
to shunt the 'back emf' when the coil is switched off - to avoid
damaging my transistors).
I've also seen this problem in other switching applications (not
relays).
Am I getting my transistors too hot when I'm soldering, or is there
something I should be looking out for to avoid this problem?
Cheers
Glenn
or similar).
relays).
Cheers
Glenn
