Do you think NI can fix my PLL?
Discussion in 'Electronic Design' started by Chris Carlen, Jun 2, 2006.
  1. Chris Carlen
    Chris Carlen Guest
    Hi:
    I'm attempting to build another motor PLL system and running into some
    difficulties stabilizing the loop. Since there is a lot of work to do,
    I have considered contracting out the PLL design to a well known control
    expert outside of my company, so I can focus on building other
    subsystems of the project.
    Basically, the PLL is to lock a 136mmx2.54mm Al wheel to a 400Hz
    reference (24kRPM, 1 pulse/rev position sensor). Must be 2nd order PLL
    yielding zero phase error with constant frequency input. Wheel to be
    driven directly by a Maxon 200W brushless DC motor with an Advanced
    Motion Controls B15A8 PWM servo driver running in open loop mode. I
    have found that the open-loop mode of the motor drive results in not
    very linear DC transfer of ref. voltage in to motor phase voltage out,
    as well as not yielding a very linear dynamic response as well (rise
    time != fall time, but only by about 10-20%).
    I have suspected that this may be the root of why the PLL behaves quite
    a bit less stable than my modeling predicts.
    A co-worker involved in the project has contacted National Instruments,
    and they will come in next week to tell us "what we need". I have
    serious doubts that NI solutions will either be appropriate from a
    design perspective, nor able to achieve results quicker/less costly than
    if I get a control expert on the task.
    I suspect from what I've heard my co-worker say (he is a LabView
    programmer primarily) that what NI has to offer which applies to PLL
    implementations is a LabVIEW-FPGA platform. This would implement
    digital filtering of the sort needed to stabilize the loop. Of course,
    then also some digital IO would be needed to accept the reference and
    wheel position sensor signals, and D/A output to drive the motor power
    drive.
    What is the view of "the SED community" on the appropriateness and
    likelyhood of success with this approach?
    My assertion has been that PLL stabilization is not something that can
    be done the way most controls are handled around here (usually PID)
    where you can use heuristic algorithms to getting it to work). Rather a
    PLL must be computed via classical analysis and servo loop design
    methods, ie, do the math.
    Since the LabVIEW guy has no such experience the only possible way this
    could work using the NI approach is if:
    1. NI has PLL tuning algorithms that can "autotune" successfully.
    2. OR NI will also provide us with contracted design assistance to
    have one of their experts tune and set up the digital filtering LabVIEW
    code.
    4. AND I am wrong about the need for analysis to solve this PLL's loop
    stabilization requirements.
    3. AND I am wrong about the non-linearities being the root of
    difficulties. Although, a digital platform might actually help in this
    regard if some sort of linearizing function must be applied. I suspect
    however, that this would be better solved by a simpler minor-loop
    synthesis approach. Ie, run the motor in speed servo mode using the
    drive and a speed feedback sensor (which should then be highly linear),
    and build the PLL around that.
    What do you think?
    I am quite opposed to this situation of employing NI, but need to keep
    an open mind. But from an engineering perspective, I think it is absurd
    even if it ultimately works to employ vastly complecx FPGAs and ultra
    high-level programming software, DAQ systems etc. to do the job of
    something that should be doable with a couple op-amps and a handful of
    resistors and capacitors.
    Thanks for input.
    Good day!
    ________________________________________
    Christopher R. Carlen
    Principal Laser&Electronics Technologist
    Sandia National Laboratories CA USA
    NOTE, delete texts: "RemoveThis" and
    "BOGUS" from email address to reply.
  2. colin
    colin Guest
    ~~ snip ~~
    I have no idea about what NI can do for you, but I notice you have 2 lots of
    90' phase shift within the PLL loop so the maths is not like an ordinary
    electronic PLL, the conversion of rpm to phase difference unavoidably shifts
    90', the mass of the flywheel also provides 90' phase shift - above a
    certain frequency determined by mass of the flywheel and the series
    resistance of the motor etc. this makes for a second order loop already but
    with no polo/zero compensation providing loop stability. I dont know what
    you have put in your model or if you have a loop filter as well, but it
    should be able to model it quite well even in a circuit simulator converting
    the mass of the flywheel to an electronice equivalent.
    To get it to work you would need to make sure the open loop PLL gain is 90'
    at and around unity gain, this could well mean a very much lower loop gain.
    Idealy the motor would have speed feedback to remove the phase shift from
    the flywheel, isnt the servo loop capable of doing this or is there a reason
    why it cant be used ?
    Another option is to use a negative impedance motor driver wich compensates
    for the voltage drop acros the motor resistance thereby minimising the lag
    cuased by the flywheel (will then be slew rate limited).
    I have done washing machine motor speed feedback controllers and many vco
    type PLL, but not motor phase control, what your doing sounds far more
    interesting than washing machines .... zzzzz
    Colin =^.^=
  3. Tim Shoppa
    Tim Shoppa Guest
    "Doing the math" is great if you've got a precise model of the behavior
    of the system at each VCO/Control voltage.
    Over small changes in load/frequency you probably only need two or
    three numbers to characterize the system over the small linear regime
    and you can "do the math" classically.
    But when the system (in your case, not just electronic but
    electromechanical) is not truly linear but may be nonlinear over
    typical range of operation, and ESPECIALLY if you've got noise into
    your phase detector, then the classical math is no longer so easy.
    The classical PLL math is still relevant to understanding the system
    and explaining why it's screwed up at certain regimes.
    It is not necessary to do all the classical PLL math to come up with a
    working PLL. You'd be surprised at how many were done by
    seat-of-the-pants hey-lets-change-parts-until-it-works methods :).
    One thing that going digital allows is easy variablee tuning of filters
    (in the case of a PLL usually low-pass filter) to the
    averaging/windowing parameter that is relevant.
    Tim.
  4. Joerg
    Joerg Guest
    Hello Chris,
    In that case you might want to give Tim Wescott a ring:
    http://www.wescottdesign.com/contact.html
    He know this kind of stuff quite well.
  5. Chris Carlen
    Chris Carlen Guest
    Yes, I have modeled the motor as an electronic equivalent circuit, and
    set up loop compensation to provide >45 deg phase margin at unity, also
    -6dB/oct slope through unity. On PM DC motors it worked very well, but
    with the brushless not so well. The indication that something is
    screwey is that when I made a quick adjsutment which improved phase
    margin at the expense of gain in the simulation, the actual PLL behaved
    worse, not better.
    The motor drive is capable of speed servo operation but needs an analog
    speed signal. The only way to get this is by F-to-V conversion from an
    encoder, since no analog tachs are available for these motors. This is
    an open possiblity, and I expect should improve things. But then it
    would be impossible to get PLL BW to be more than a fraction of the
    servo BW. This is probably Ok though since it only runs at constant speed.
    I'm considering going into the washing machine controls business after
    this, actually. I need some relief from complicated stuff.
    Good day!
  6. Chris Carlen
    Chris Carlen Guest
    I have found this to be possible with normal VCO PLLs, but motors
    present extra difficulties due to the need for an extra lead network.
    Because of this I have found myself only making things worse when using
    the "changing parts" method with motors. Then when I sit down and do
    the math and get it to look right on the AC analysis in SPICE, the real
    thing works just as advertized. Just having some gotchas with this
    3-phase brushless DC thingamabob.
    Yes, that is true.
    Thanks for the input.
    Good day!
  7. Chris Carlen
    Chris Carlen Guest
    Yes,
    "well known control expert" == Tim Wescott
    Good day!
  8. Mike Monett
    Mike Monett Guest
    This is a critical portion that you need to know inside and out. If you
    outsource, you will be constantly calling the guy whenever something goes
    wrong or doesn't work quite right.
    What kind of problems are you encountering? If the loop is wildly unstable,
    it obviously needs to be fixed. If you are asking for extremely tight
    control, i.e. picoseconds of phase error control in milliseconds of
    rotational period, maybe the requirements are too tight and need to be
    relaxed.
    Small errors like this should have little effect. In a normal loop, changes
    in the response go as the square root of gain. For example, you can run a
    varactor pll from one end of the range to the other with satisfactory loop
    response even though the vco gain changes quite a bit.
    Putting Windows software in the feedback loop is a recipie for disaster.
    Any consultant that recommends relying on Windows has no concept of system
    reliability and should be shot without benefit of blindfold.
    You are absolutely correct. Any other seat-of-the-pants approach will not
    work. I've tried. You cannot possibly arrive at the proper loop components
    by guessing.
    After doing the math and simulations and getting the loop operating
    correctly, you can trim the values to optimize the response at a desired
    operating point. But not before.
    Highly recommend do not rely on Windows software to close the loop.
    This seems to be the root of the problem. Instinct tells me there is
    something being overlooked. PLL motor speed control is not that difficult.
    Extreme linearity is not needed. You can get the loop operating fairly
    well, then trim to optimize the response.
    Follow your instincts. You are correct.
    Regards,
    Mike Monett
  9. colin
    colin Guest
    Maybe the difference is that the brushless type doesnt like being reverse
    driven so the time constant of the motor/flywheel is variable depending much
    more on load when it is slowing down.
    speed.
    Well you already have an encoder albeit 1ppr, plus the frequency of the
    solid state commutation must be available somehow. F to V is easy todo. if
    only you could limit the frequency of commutation directly, say with a
    voltage controlled monostable trigered from one commutation pulse wich
    prohibited the next comutation pulse until it had timed out.
    or maybe a micro controller might be the best choice here as it should
    easily be able to take the pulse and use it for phase comparison and motor
    speed feedback, a loop filter is simple to code or you could still do it in
    analogue.
    Another option is to cancel the phase lag with a phase lead circuit, also if
    the motor takes longer to slow down than to speed up maybe you can
    counteract this effect with a diode in conjuction with the resistor in your
    loop filter or with phase lead circuit as well.
    Colin =^.^=
  10. Jim Thompson
    Jim Thompson Guest
    [snip]
    Have you considered doing it the other way around?
    50 years ago when I was a student at MIT and was teching for the MHD
    group, I synced all the associated triggering electronics to the smear
    camera flywheel with a photo pickup (PMT).
    ...Jim Thompson
  11. Joerg
    Joerg Guest
    Hello Mike,
    Errr, that's not how consultants with good ethics work. At least I
    don't. A good consultant will look at the problem, figure out a solution
    and then explain in great detail (and in writing) why he or she did it
    this way. And possibly also outline why other approaches were not taken.
    My clients generally receive a reliable design plus a tutorial. They
    like it that way. I always ask them whether there is an engineer I could
    take along through the diagnostic and design phases so next time they'll
    be able to get going on their own.
  12. Mike Monett
    Mike Monett Guest
    Brilliant. The same concept could probably be used in many other areas.
    However it would be nice to have the speed control reasonably stable. This
    is for the occasions when the lab director walks through. You don't want
    him to hear the whooping whine as the speed control hunts for the correct
    speed:)
    Regards,
    Mike Monett
  13. Mike Monett
    Mike Monett Guest
    Have you dealt with Labview consultants? Did you read Chris's report on
    their approach?
    Changing to a complicated system that relies on ADC's and DAC's using
    Windows software is a road to ruin.
    My comment stands. Chris has done most of the work already. There is
    something simple that needs to be fixed.
    And I'm certain Chris had a much better handle on the math as well as
    associated hardware issues such as proper layout and gounding to eliminate
    noise issues.
    He is simply the best person available to do the job.
    Regards,
    Mike Monett
  14. Jim Thompson
    Jim Thompson Guest
    In my day I didn't speed control the motor. I had built a ~90° phase
    shifter and two 400W amplifiers (tubes ;-) to drive the synchronous AC
    motor. Then I brought it up to speed slowly and carefully, tweaking
    the phase-shifter all along the way.
    When I had the speed correct I hit the trigger button and the next
    time the mirror was in the proper place the MHD tube was "fired".
    More instantaneous power than all the power stations in the United
    States combined ;-)
    ...Jim Thompson
  15. Mike Monett
    Mike Monett Guest
    I see little has changed:)
    Regards,
    Mike Monett
  16. Joerg
    Joerg Guest
    Hello Mike,
    Tend to agree here. That's why I suggested Tim.
    Well, he said he thought about handing it off in order to free up some
    of his time. "...so I can focus on building other subsystems of the
    project" were his words. Nothing wrong with that IMHO.
    Most of the tasks that I am called out for as a consultant were
    initially thought to be "something simple that needs to be fixed". Some
    of them were (but not by the staff alone), others had a few hardcore
    problems underneath the surface. It has happened that clients said at
    the end "You mean, that's it?". But they would have had a hard time
    finding it out on their own, for example that #77 ferrite material could
    not possibly have worked in a certain situation.
    From what he wrote it looks like he may not have the time. It might be
    very worthwhile to secure the help of an expert even if he does it
    himself. Half a day of help by a consultant can often save a week of
    trial and error.
    Just one example: Had a call from a client at lunch today. They got
    stuck with the procurement of a few parts. Would have taken them hours
    to find and they'd have missed today's order deadline, causing a slew of
    other problems. My billed time was a whopping 15 minutes and for that
    they got part numbers, source, qties in stock, pricing, and how to find
    these on their own next time.
  17. Joerg
    Joerg Guest
    Hello Mike,
    Oh, I can already smell a nice exchange of political rants coming up and
    we aren't even close to elections yet :)))
  18. Jim Thompson
    Jim Thompson Guest
    It's like audiophool specs... peak ;-)
    But the floor of Building 20 did flex ;-)
    ...Jim Thompson
  19. Chris Carlen
    Chris Carlen Guest
    I think the arrangement would be to work closely together, where I would
    learn how the loop was optimized so I could probably handle future
    adjustments.
    The requirements are not terribly difficult initially. About +/-0.5
    degreees jitter is tolerable. But there is another dimension to the
    project to explore syncing two wheels together. This will need to be
    about 0.01 degrees p-p.
    My problem is that when I did it with a PM motor, it worked very well.
    Hardware behaved with a few % of the sim. Moving to brushless is
    faltering, though the circuit is basically the same.
    Yeah, that's right, which is why I am surprized it is proving cantankerous.
    Mike, it wouldn't be Windows. It would by LabVIEW running on a
    dedicated real time CPU or FPGA. Windows might be involved at a higher
    level of "stop/go" that sort of thing.
    Don't get me wrong, I still think it's a non-ideal approach.
    Hmm. Will have to try a bit harder to see what can be done here.
    Thanks for the response.
    Good day!
  20. Chris Carlen
    Chris Carlen Guest
    I didn't mention that two wheels have to be locked together, ie,
    electronically geared. It isn't that the wheels are being synced to an
    experiment. Rather, a fast wheel controls an experiment, and a slower
    wheel gates out too frequent events from the fast.
    Good day!
