Do USB ports (for charging only) require FCC certification
Discussion in 'General Electronics Discussion' started by DON MATTEO, Feb 20, 2020.
  1. DON MATTEO
    DON MATTEO
    Feb 20, 2020
    I would appreciate if someone can let me know if the "regular" USB ports that are only for charging and not for data transfer require FCC certification.
    Also, is there any UL standards that these USB ports should comply with?
    Thank you
  2. Audioguru
    Audioguru
    2,792
    633
    Sep 24, 2016
    A USB port is 5V and is not a charger circuit because nobody makes a 5V battery. The Lithium battery in a phone charges to 4.2V or less, at a certain current designed for it.
    Instead a USB 5V is used to power the charger circuit inside the phone.
    Since the charger circuit does safe charging to prevent the battery from exploding then the USB port does not need FCC certification.
  3. hevans1944
    hevans1944 Hop - AC8NS
    4,460
    2,075
    Jun 21, 2012
    Unless, perhaps, it uses a high-frequency switch-mode supply. I don't know if those need FCC approval or not.
