Hello,
I'm far from being an expert, so sorry if I the question is very simple.
I have a 1200W 220v clam-shaped pizza oven with two resistors connected in series: the first resistor is under the stone and the second in the upper part of the oven.
After having modified it, the oven reaches the temperature that I wanted. Problem is that the stone gets too hot and burns the pizzas at the bottom.
My solution: put the resistors in parallel and switch off the resistor under the stone when it gets too hot (I have installed a thermocouple to control that).
My problem: the resistors can likely work at 110v but not at 220v. How can I work this out? My weak electric knowledge would suggest me to use a diode to cut the wave, but I guess this is not correct.
Any suggestion would be appreciated.
Maurizio
Maurizio
