Do I need a heatsink? How big?
A simple inroduction to heatsinking components
  1. (*steve*)
    25,482
    2,830
    (*steve*) submitted a new resource:
    Do I need a heatsink? How big? - A simple inroduction to heatsinking components
    Read more about this resource...
  2. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    What example can you show where heat is dominant over temperature for components? I guess you mentioned this for a reason.
  3. (*steve*)
    25,482
    2,830
    The example will be when you add a heatsink. Not only does it increase surface area for dissipation of heat, but the entire system now has more thermal mass meaning that it will take more heat to reach a given temperature even if we disregard the dissipation of heat into the environment.
    Heat is never really dominant over temperature (did I say that in the resource?) but the larger the thermal mass, the slower the system will react to a given heat input. This is good for things like intermittent operation. Whereas thermal resistance can be seen as resistance, thermal mass looks like capacitance. So with these resistors and capacitors we end up with a low pass filter. If the resistances are low enough and the capacitances high enough, they will load down the input. Not good for an amplifier, but great for a junction with a peaky power dissipation.
    Will I cover this? I'm not sure. Maybe it will get edited out if I don't.
    Care to comment on phase change being listed as a 4th method under convection, radiation, and conduction? It's a bit of a stretch (and arguable whether "phase change" is the best term).
  4. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    No you didn't say heat was dominant, it's just you said is heat our enemy? Which I took as it could be at some point. Regarding phase change, well I suppose you could say it does release heat. After all steam when it condenses releases heat, the same heat that caused it to change state in the first place. But I am no metal expert but I assume it's game over for the component once it has changed state (Phase change) because this would be at a very high temperature. One thing I am not sure on is what happens to a metals thermal inertia when it's changes phase, I don't mean changed to liquid but at certain temperatures the crystalline structure can change several times before it reaches melting point.
    Adam
  5. (*steve*)
    25,482
    2,830
    Each of these phase changes will have a latent heat associated with them. The heat is dissipates by breaking bonds between molecules.
    In a very loose way, things like causing ions to diffuse through the semiconductor could be seen as a type of phase change (perhaps)
    Still wondering if there's a better way to put it.
    Anyway, I've added a little more, but there's plenty to go.
  6. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Looking good Steve.
  7. (*steve*)
    25,482
    2,830
    Almost half way there...
  8. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    This is great stuff Steve! I'll post some minor comments when I get to the end.
    (*steve*) likes this.
  9. (*steve*)
    25,482
    2,830
    Thanks Kris. I have some more stuff lined up to put in whenever I get time to scratch
  10. hevans1944
    hevans1944 Hop - AC8NS
    4,592
    2,149
    Jun 21, 2012
    Please finish Section 6.
  11. (*steve*)
    25,482
    2,830
    ok... :)
  12. bertus
    bertus Moderator
    1,677
    651
    Nov 8, 2019
  13. hevans1944
    4,592
    2,149
    Jun 21, 2012
  14. bertus
    bertus Moderator
    1,677
    651
    Nov 8, 2019
  15. WHONOES
    WHONOES
    1,115
    310
    May 20, 2017
Similar Threads
Loading...
