S
Skype_man
Bad question, I know. Does RCA have a DLP problem?
Just got two 50" units in, only out by one number in their
serial number. Example: 1234567AB, & 1234567AC.
One dead right out of the box, the other dead, after not
much use. They were made in Feb 2005. Called Tech
support, we are ASC. One guy said: Light engine bad,
which is about $ 1,800 can, another Tech said: Lamp
bad, about $ 250 can. What's a Tech to do? I haven't
even seen a partially working unit yet, to know what it
sounds like when starting up, & running. How can you
test a DLP lamp? There expensive, & you can't measure
them, to be sure? Can you set up a test jig, to test the lamps?
Sky.
Sky.
