DIY Wii Peripheral, anybody have experience?
Discussion in 'General Electronics Discussion' started by muse7789, Nov 28, 2011.
  1. muse7789
    muse7789
    Nov 28, 2011
    Hey guys,
    I am trying to build a simple Wii remote peripheral for a project. I want to wire this potentiometer (http://search.digikey.com/us/en/products/EVW-AE4001B14/P12426CT-ND/637165) to the I2C bus port on the back of the wii remote. It will read data from a trigger of a wii-mote attachment I am working with. This port should read analog data because the wii nunchuk has an analog stick. I am trying to get the wii remote to interpret the pot's reading as it would interpret a single axis from the nunchuk's analog stick.
    I am using Darwiin Remote to observe data from the wii remote graphically on my computer.
    My problem is that I'm not sure what chip (if any) I would be best using for this. I've got an old nunchuk that I can use but that chip will handle so much more (two pots, an accelerometer, two buttons) than I need, there must be a simpler way to do it.
    Anybody have any thoughts or ideas?
    here are specs on the I2C bus port:
    http://www.hardwarebook.info/Wiimote_Expansion_Port
    Walter
    ( :eek: I'm not super experienced with electronics, any help is great help! )
  2. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    Hi muse7789!
    The PCF8591 is a popular A/D converter. You can connect your pot(s) analog or accelerometers on it. With voltage dividers it can also be used for switches. Sure you need a piece of code. Maybe Darwiin Remote have a list of supported I2C devices, if so just tell us and I will have a look on.
    Olivier
