DIY PCB toner transfer
Discussion in 'Electronic Design' started by [email protected], Jan 18, 2007.
  1. Guest
    I don't make my own PCBs, but something I've not seen mentionned in the
    laser toner transfer technique is that the paper backing for adhesive
    labels is perfectly calandered (ie smooth) and will gladly release the
    toner with just a bit of heat. The bonus is that this type of paper is
    free. Just look out for the lines where the die-cutting blades cut.
    Basically you just print on the smooth side and there you go.
    I've used Corporate Express EXP00716 labels and made a test etching for
    a mixer board. I think it went fairly well, but I never soldered to it.
    (I just plop the parts right on the mixer, it works)
    I believe the idea is that this paper won't grab to the toner
    preferentially to the rougher copper surface.
    Anyways I just thought I'd toss that out there. Do with it what you
    will.
  2. D from BC
    D from BC Guest
    Neat...Might try someday..
    On that topic..
    If you're experimenting with spray coatings on laser transparency
    film, please post the results.
    It's related to my post entitled "pirated press n peel"..
    D from BC
  3. SFC
    SFC Guest
    This works great! I always used the photo methode but this is so easy with
    very good results. 0.3mm tracks are no problem. Look here how to do it:
    http://www.headwize.com/projects/garbz2_prj.php Or google for 'toner
    transfer'.
    I use 170 gr. photo paper with a laserprinter. You can also make a silk
    screen the same way (only black) which make it even more professional.
    SFC
  4. jasen
    jasen Guest
    I've used label backing for other iron-on projects and found it works well.
    IIRC Avery make one with a full-page sized label (so no cutting lines)
    And it's reusable.
    You can run the paper through multiple times for extra darkness if you're
    careful with registration.
    Bye.
    Jasen
