John Popelish
Terry Pinnell wrote:
(snip)
The voltage between the bases of Q3 and Q4 have to not only force
those two transistors into slight conduction, but Q5 and Q6, also. I
would connect a millivolt meter across R11 and raise the bias voltage
until a few millivolts drop was visible. But, as I said in an earlier
post, this will require at least 3 diode drops between the basses of
Q3 and Q4. After you set the quiescent current through R11, go back
and measure one of the diode drops (D1 or D2) and the total voltage
between the bases of Q3 and Q4 to see if I am right about this.
(snip)
I intend to replace the two presets for setting the output DC level
and quiescent current respectively. The first is obviously easy to set
(half supply voltage), but how do I determine optimum setting for
quiescent current please?
